Replaced cartridge in Shower Water still leaking
Discussion in 'Shower & Bathtub Forum & Blog' started by stevebdenver, Dec 8, 2009.
  1. stevebdenver
    stevebdenver DIY Junior Member
    Dec 8, 2009
    denver co
    I have a price pfister shower unit that was leaking out of the head with the water in the off position. I replaced the cartridege last night and the water still leaked. The flow was much slower but still leaking. I talked to a local plumber and he said the city may have increased my water pressure and its causing the water to blow past the shut off. He reccomended a $400 with parts fix. Is this sound plausible? Or is there anything else i can try.
  2. jadnashua
    No, not in my opinion. Unless your water pressure is exceptionally high, a new cartridge should not leak. It might wear out faster, but when new should work. The simple thing to do is stop at a plumbing store (the big box stores like HD carry them too) and get a water pressure gage. Get one with a max pressure needle. Stick it somewhere in your house and let it sit for 24-hours (pressure can rise a lot overnight as they refill the towers and use is low). You can buy them with a hose bib connection. Or buy adapters and put it where you want. If it is over 80#, you should probably have a pressure reduction valve AND expansion tank installed. Otherwise, your valve may be worn out of you used a generic, rather than OEM cartridge, and you need a new one again.
  4. Terry
    Aug 17, 2004
    If you have the Avante valve, make sure it's made by Price Pfister, and not a knock off.
  5. hj
    leaks
    Which PricePfister valve do you have. NONE of them will leak unless your pressure were beyond any normal limits, but then you would have a lot of other problems also. He is trying to sell you something you do not need. Either you did not replace everything that was needed, or you did it incorrectly.
Similar Threads: Replaced cartridge
Shower & Bathtub Forum & Blog HELP!...Leaky Bathtub faucet even after I replaced both cartridges Jul 2, 2013
Shower & Bathtub Forum & Blog Just replaced Moen posi temp 1222 cartridge and it leaks Jan 4, 2013
Shower & Bathtub Forum & Blog new Am Std cartridge leaks...replaced still leaks Sep 6, 2008
Shower & Bathtub Forum & Blog replaced Moen cartridge 1222B posi-temp, now temps all wrong Mar 25, 2007
Shower & Bathtub Forum & Blog replaced cartridge, still leaks! Nov 16, 2004
