replaced bladder-water shuts off
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by s.kanupp, Apr 3, 2008.
  1. s.kanupp
    s.kanupp New Member
    Apr 3, 2008
    I let an friend with alleged knowledge of well pumps replace water bladder in garage, (I had been having to add air for months). Now in the mornings after short shower the water runs out. Takes 10 minutes before water will come back. What can I do now? I have very limited knowledge, never had problems before? Thanks, Stephanie
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Chances are, your well is not producing the water you require, or the pump can't keep up for what ever reason.
    The tank is only as good as the drawdown it has. Which in most cases is less than 20 gallons. Then it's up to the pump and well to keep up with demand.
    bob...
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Could it be as simple as too much air in the tank? If the air pressure is too high the pump won't run.
    Sounds like a good time to have a knowledgeable person check out the system.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Start reading here. This should explain more than you ever wanted to know about Bladder Tanks.
    bob...
  6. hj
    tank
    If the pressure it too high the pump WILL run, but it will turn on and off much too frequently when water is being used.
Similar Threads: replaced bladder-water
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Replaced check valve, now no real flow. Aug 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump will not cut out after pressure switch replaced Jul 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Black sooty water with a greasy film from a water well with recently replaced pump Oct 10, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replaced Well Tank and now funny pump start Oct 5, 2014
