Sarah777
Hello! I have a 2-line jet pump (In the house) which started running when no water was on and no leaks inside house. I have had the foot valve replaced 3 times in the past 6 months and the problem persists. The pump runs every 9 minutes now/still; it runs normally when water is being used. The well is 80 feet deep with about 40 feet of water, 6" casing, dates to 1969. The pipes inside the well were pressure tested and the pressure dropped a little, but that was before the last foot valve replacement. Any ideas? Thanks!
