Replace tub drain/strainer
Discussion in 'Shower & Bathtub Forum & Blog' started by rascal2, Dec 28, 2007.
  1. rascal2
    rascal2 New Member
    Jul 27, 2007
    I am renovating a bathroom and want to replace the chrome fixtures with brass. I am concerned with how to replace the chrome tub drain/strainer with a brass replacement set. In particular, I want to be sure that removing the tub strainer will not result in the waste pipe slipping away from the tub because I can not get to it from below or the side (no access panel). Can I just screw the chrome one out and screw the brass one in as a replacement? Does the drain pipe have to be supported from below while this is being done?
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Usually, the tub drain can be screwed out, but it depends on a number of factors. In some cases, the old drain is all but welded in place and has to be cut loose. Access to the area beneath the tub would be very helpful in a case like that.
    Sometimes, the cross in the strainer breaks out, leaving you with little choice.
    Is the tubing brass or plastic? Does it have rubber washers, lead washers, or plastic washers in the slip joints? All these things can be a factor in whether it's an easy job or a nightmare.
    I can understand why you'd like brass, but is the brass of high quality? New major brand brass faucets use a titanium technology that is actually tougher than chrome, but the cheap stuff is still likely to deteriorate in a relatively short time.
Similar Threads: Replace drain/strainer
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
Shower & Bathtub Forum & Blog How do we replace 5'0 bathtub with minimum damage? Jan 5, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Replace shutoff valve Dec 7, 2016
