Replace Sloan Flushmate in Crane Bowl with Gravity Fed Parts?
Discussion in 'Toilet Forum discussions' started by tranman, Mar 20, 2011.
  1. tranman
    tranman New Member
    Mar 20, 2011
    Orange, California
    I recently bought a home with a Sloan Flushmate pressure assisted system in a Crane toilet bowl. It requires multiple flushes so I bought Fluidmaster gravity fed fill and flush parts.
    I installed the Fluidmaster parts but I can't seem to get a good enough flow out of the jets to get the toilet to flush. I tried thought it might be calcium buildup so I cleaned the jets both bottom and rim with vinegar and cleared them with the end of a coat hanger but no luck.
    Is the Crane toilet bowl designed only for the pressure assisted Flushmate?
    Any help would be very helpful! Thx!
  2. Terry
    Aug 17, 2004
    Pressure assist bowls are specifically designed to flush with the Flushmate pressure assist.
    The trapway design is different.
    If you intend to keep the bowl, you will need a replacement Flushmate.
  4. tranman
    tranman New Member
    Mar 20, 2011
    Orange, California
    Bummer, was hoping to not have to replace my bowl. Thx for the info!
  5. Terry
    Aug 17, 2004
    Why did the Flushmate require multiple flushes?
    They have a 1-800 number on the tank that lets you talk to a tech support person to troubleshoot the problem.
    [​IMG]
  6. schipperke
    schipperke New Member
    Dec 10, 2010
    Maryland
    Instruction Manual
    See if you can trouble shoot it. I had a Crane Flushmate, many many years worked great.
    Flushmate 503
  7. hj
    If a pressure assisted toilet loses its "air bubble" in the tank, it will NOT flush properly, and can require two flushes or one while holding the handle down.
  8. Paul DeBoo - Sloan Flushm
    Paul DeBoo - Sloan Flushm Flushmate
    Oct 8, 2010
    New Hudson, MI
    There are some simple troubleshooting tips to evaluate the Flushmate system, as Terry has indicated, please contact Flushmate directly or visit their website. View the video section for troubleshooting.
Similar Threads: Replace Sloan
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Norris toilet replacement with a Toto? Jan 31, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
