Replace or use existing flange?
MattD
Hello folks, new member here. I've read a lot on this forum searching for an answer to my question but I wanted to post some pictures to make sure I do it right.
I tiled a bathroom and overlooked thinking about the toilet flange at all. First timer...
So I'm wondering if the metal flange around the PVC will work or if I should replace it or put in an extender? The pipe is 3in, and the tile is about a half inch above the metal flange. I've also read about using two wax rings, is a half inch a small enough difference that I could get by with two rings? More than anything I'm just hoping I haven't made any huge mistakes...
Anyway, here is what I'm looking at:
I appreciate the help and look forward to using this forum in the future.
Cheers!
It looks like you have the remnants of a flange in that bottom picture. What is the ID of that inner hole, and what is the ID of the white pipe that the inner pipe is?
MattD
I did measure the inside hole and it is 3 in. I'm not at home right now so I can't measure the outside, but I'd guess it's 4 in. I can get an accurate measurement later.
To be clearer, I am referring to the area where I have drawn the red and green circles.
Do you have a more accurate measurement method available? A 3 inch schedule 40 PVC pipe is 3.5 inches OD and about 3.042 inches ID. If the inner hole is under 3 inches, that would imply that something has been glued inside, and I suspect that might be the remnant of a flange. If you have the full 3.042 inches ID available, there are easier options.
Wallijonn
Arizona
Maybe a Harvey's #10 extra thick wax seal will be good enough. Maybe. You could always add a flange extension, though. Or go with two regular sized wax gaskets, one with the poly flange and one without. It depends on how far down from the top of the tile it is. Your pictures would seem to indicate about 1/4".
If it fits, I was thinking a 1/2 inch spacer topped with a Sioux Chief closet flange 888-PM. That flange has a longer tail that will extend down farther than most. But if the remaining hole is under 3 inches, that inner part would have to be removed first. It can be done, but not so easily by a DIY.
MattD
Thanks for the input. I'll try and take more exact measurements when I get home tonight.
MattD
I measured the diameter of the inside pipe as best I could with an everyday tape measure it is just under 3". Not by much but definitely under.
The top of the tile is a little under a 1/2" from the top of the existing metal flange.
MattD
Could I just remove the metal flange and stack two "raise-a-rings"? I think that would make it level with the new floor.
I thought that your second picture showed that you had already removed the metal ring that shows in your second picture. No?
If you are asking if you put a 1/2 inch spacer over the plastic that is in place, seal as needed, and then screw your existing stainless ring through the spacers into the floor, with no new closet flange plastic, I don't know.
MattD
Yes I took it off for the picture. It was only screwed into the subfloor a couple times, it wasn't connected to the drain at all. I could just screw it back in place if necessary.
IF what you have left there is a typical flange with a metal ring, they make split repair rings that are designed to fit into the notch around the pvc part, and when you close it up and screw it down, it holds it tight to the rest of the flange. While the ideal place for the flange is on top of the finished floor, once you get that tight, I'd probably use stack a couple of wax rings. Terry likes to use one with a horn for the top of the stack, and a plain wax ring for the bottom one. The horn helps to keep the lower one centered, and since you have the depth, the plastic horn won't cause problems like it can when the flange is higher.
