Replace or Not?
Discussion in 'Electrical Forum discussion & Blog' started by Mikeyboy, Jan 24, 2009.
  1. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    My entire house has non-ic recessed cans and I just replaced all the trims with air-tite trims for all recessed lights that has an attic above. This is to hopefully prevent any air leakage going in or out through those fixtures.
    Should I replace those trims with air-tite trims that have bedrooms above the fixtures? Would I be losing heat through those cans or would any cold air be coming in through those cans if a bedroom is above it?
  2. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Don't you think you should have isulation compatible bodies for those light fixtures since they are in the attic?
  4. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    When we bought the house two years ago, the previous owner went the inexpensive route with the non-ic fixtures. I dont have the funds to replace them right now so I thought the air-tite trims would help decrease the amount of heat loss. Wont it?
    Should I replace the trims between the floor spaces?
  5. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    If the cans aren't air tight or IC rated & covered with insulation then you will lose heat thru them
    If you have access from the attic many people box these in with drywall , seal it, then cover with insulation to cut down on heat loss
  6. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    I thought the bigger issue was not letting insulation touch a non IC compatible body because of risk of fire. I believe the IC bodies have extra thickness and protection, that's why you can put the insulation right over them.
    Yes, I'm talking about the body of the high hat in between the spaces of the ceiling. You probable have insulation in your attic that's touching the body of the high hat. If it's not rated for insulation then the insulation shouldn't touch it.
  7. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    I have 17 light fixtures all together that I installed air-tite trims. I only have access with 6 of the 17. The remaining 11 are not accessible due to small attics or are in cathedral rooms.
    Can someone please answer if I should replace the trims between the floor spaces?
  8. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    You can better answer this question yourself.
    Do you want to change the trims? Here in lies your answer.
  9. Mikeyboy
    Mikeyboy New Member
    Nov 29, 2008
    I really dont know how much heat loss if any is going through those light fixtures in between the floor spaces. I dont think there is installation there. Is there? They are easy to change but if it wont make a difference then I wont bother.
  10. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    Between floors? Don't bother. Unless the upstairs is a finished attic that wasn't always finished, there's not likely going to be any insulation between floors. Nor would I be worried too much about heat loss between floors. There's plenty of heat that goes up the stairs to get to the 2nd floor, no?
Similar Threads: Replace
Electrical Forum discussion & Blog GFCI replaced, now regular outlet is dead Feb 14, 2016
Electrical Forum discussion & Blog Can horizontal radiant heaters be replaced with in wall units? Nov 12, 2015
Electrical Forum discussion & Blog Dual Trip Breaker Replacement Jan 25, 2015
Electrical Forum discussion & Blog Electric Motor - ID / replacement help Jan 23, 2015
Electrical Forum discussion & Blog electronic ignition fireplace won't start when lights are on Mar 7, 2014
