Craif
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I have removed my toilet to install tile flooring. During the removal of the old tile, I damaged the cast iron flange and figured, no problem, I'll just replace it. Upon closer inspection, I realized that the flange is practically integral to the cast iron elbow drain pipe. So, now I have a damaged flange and I'm not sure which direction to go next.
The flange appears to be about 4" I.D. and the drain pipe measures about 3" I.D. Between the flange inner circumfrence and the outer circumfrence of the drain pipe, appears to be about a 1/2" filler of a very semi-hard, maleable, metallic substance (lead?).
Should I continue breaking off the flange and leave the rings and then install a flange fixer over top? Or, should I try to bang the whole flange assembly off so that I can install a new one?
See attached photo.
See attached photo.
