Replace Flushometer with Tank Style?
Discussion in 'Toilet Forum discussions' started by Madera, Jun 16, 2005.
  1. Madera
    Madera New Member
    Mar 29, 2005
    Per a previous post, I have a floor-mounted flushometer toilet in my apartment. Should I replace it with another newer flushometer, or a tank-style toilet? What are the pro's/con's of each (difficulty of project? cost? does it affect resale value?)?
    I am considering replacing it with the Gerber Flushmate with a 10" rough.
  2. Terry
    Aug 17, 2004
    I wouldn't know about the resale difference between the two,
    Since you have a 10" rough and flushometer style, the easiest for the plumber would be the same type replacement. No plumbing is required for this.
    It's just bolt in and out.
    [​IMG]
    Toto CT705
    If you go with the Gerber with tank, the plumber will need to get into the wall and move the water supply.
    Either way, you will be moving 1.5 to 1.6 gallons of water.
  4. Madera
    Madera New Member
    Mar 29, 2005
    Exploding Flushometer?
    Another dumb question (maybe)...is there a risk of a flushometer exploding when the water supply is turned on/off for the building? I really don't want a flood (the main reason I want to replace my current toilet!).
    Many, many thanks!!
  5. Terry
    Aug 17, 2004
    No,
    Water shutdowns are common and plumbing should handle that.
Similar Threads: Replace Flushometer
Toilet Forum discussions Can I find a replacement tank unit for American Standard Flushometer powers asstis Jul 18, 2010
Toilet Forum discussions Replace Flushometer w/High Tank feed? Jun 9, 2010
Toilet Forum discussions TOTO Carlyle - flushometer replacement? Feb 25, 2006
Toilet Forum discussions Replace Flushometer Toilet with Standard Toilet Mar 29, 2005
Toilet Forum discussions Toto CST703 refill valve replacement - no refill tube Mar 13, 2017
