Replace Duct vs. Manual Damper
Discussion in 'HVAC Heating & Cooling' started by jevonmckinzie, May 11, 2009.
  1. jevonmckinzie
    jevonmckinzie New Member
    Feb 8, 2009
    Chicago, IL
    I am remodeling my home, and I am adding more insulation to the walls and sealing all the air leaks. Basically, some rooms get more air than other rooms. I am wondering if it is possible to install a manual damper inside the duct or is it better to replace the branch duct with a smaller one.
    For example, in the bathroom on the main floor, the current duct is a 6" round duct, which delivers about 100 CFM. However, the room is only 40 sq. feet and really only needs 30CFM, or a 4" round duct.
    I plan on having a variable speed furnace installed that is sized correctly, because the current unit is a single stage and it basically dumps about half of the rated CFM into the basement, which makes it feel like an oven in the winter and a freezer in the summer.
  2. 3m
    3m New Member
    Mar 3, 2009
    NY
    When they install a new furnance have this installed then you can balance the airflow, they must be installed on all supply lines off the main trunk
  4. jevonmckinzie
    Feb 8, 2009
    Chicago, IL
    Thanks!!! Seems like a much cheaper solution.
  5. hj
    air flow
    The cheapest solution would be to close the dampers on the registers so they let less air through.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    While maintaining reasonable air flow thru the HX.
Similar Threads: Replace Duct
HVAC Heating & Cooling Replace duct work or whole system? Feb 14, 2012
HVAC Heating & Cooling Gas fireplace shutting off Dec 22, 2016
HVAC Heating & Cooling Patch or Replace Plenum Dec 9, 2016
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
