Replace 2 " galvenized at vent stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LittleLisa, Apr 20, 2009.
  1. LittleLisa
    LittleLisa New Member
    Apr 20, 2009
    My house is 50yrs+ old and I am remodeling the downstairs bathroom. Since I have plumbing and drains exposed, I would like to replace the galvenized to PVC for the upstairs shower/tub drain. After I cut the 2" galvenized pipe close enough to the vent stack that I can still get a flex coupler attached, should I attempt to unthread the rest from the vent stack? How difficult will this be since I can't even break it loose to unscrew it from up above (hence cutting it instead)? The old galvenized pipe looks rusted at the vent stack and some of the old lead seal is coming out, but I"m afraid to break old vent stack it's looks in good condition and do not want to go down that road! Is there a way to make it easier to remove pipe from vent stack without breaking stack?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Lisa, Can you post a picture of this connection?
  4. LittleLisa
    Apr 20, 2009
    At vent stack
    Hopefully this works
  5. jadnashua
    If your camera has a macro mode, try that...it's hard to tell from what you've posted. Depending on the camera, it may be an icon like a flower or something like that. That will allow it to focus closer.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Or just back up a foot...
    that would be much better.
  7. LittleLisa
    Apr 20, 2009
    maybe this is better
  8. Redwood
    Dec 15, 2007
    Service Plumber
    I would just cut the pipe and attach the new to the stub using a Fernco Proflex banded rubber coupling....
Similar Threads: Replace galvenized
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Remove/replace/extend closet ring Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Replace Toilet Flange? Feb 6, 2017
Plumbing Forum, Professional & DIY Advice P Trap replacement Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
