Repipe the main line?
Discussion in 'Irrigation / Sprinkler Forum' started by gargalaxy, Apr 10, 2012.
  1. gargalaxy
    gargalaxy New Member
    Jun 9, 2011
    plumber
    florida
    The irrigation and the domestic water was connected to the same water meter in a commercial building (2" main domestic line with a T 2x1.5x2 to a 1.5 backflow for the irrigation). Two days ago the county installed a separate water meter 3/4" just for the irrigation. I had to cap the T and run about 6' from the new meter to the old line (backflow). I Checked for leaks and everything was ok. After running all zones, i noticed that the water meter is spinning slow. I checked it with my leak detector but I could not find anything. My question is: is it possible that there is not enough pressure (remember all valves are 1.5" and the connection is in 3/4) for the diaphram to close and the water is just running constantly slow? Do I have to reduce the main line and valves at least up to 1"?
Similar Threads: Repipe main
Irrigation / Sprinkler Forum Bury drip irrigation main connected to hose bib? Mar 4, 2017
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum Connect to main Dec 13, 2012
Irrigation / Sprinkler Forum Connecting irrigation to water main with pex homerun system Apr 11, 2012
Irrigation / Sprinkler Forum Mainline Repair Still Leaks Sep 27, 2010
