Reparing Unlevel, Broken Flange
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gusherb94, Mar 2, 2014.
  1. gusherb94
    gusherb94 Member
    Jan 13, 2009
    Everything
    chicago/nw IN
    How would one go about repairing this short of ripping up the subfloor and replacing the whole damn thing?
    In the picture; the lefthand side is the back of the flange. The screws have failed. When you tighten the bolts it just pulls the whole flange up, but the toilet still stays somewhat secure so I think it's relying on the pipe being up against the framing in the floor. My problem is the flange is cracked where the bolts go, and the bolts try to slide off the flange.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If underneath is a basement or crawlspace, I might cut the closet bend off and start over from there. The floor needs to be fixed and/or filled to provide a flat surface for a new flange on top of the finished floor. The riser needs to be reasonably straight for the flange to be level, and always use a flange with a stainless steel ring.
  4. hj
    If that broken slot is the rear of the flange,(and if so I cannot imagine how it got broke), the the bolts go in the two slots. Your picture does not indicate that they are cracked, but even if they are, they look good enough to hold if you use nuts and washers to secure the bolts to the flange, (which ,I and many other plumbers, always do anyway), so they cannot slip out. The unlevel does not appear to be bad enough to cause any problems.
  5. gusherb94
    gusherb94 Member
    Jan 13, 2009
    Everything
    chicago/nw IN
    Thanks, I have a toilet on there now but I forgot to use bolts with a nut to the flange so as it is now the bolts are crooked and near the edge and ready to slide out of the slots if the bowl ever gets bumped or plopped on aggressively. I'm contemplating pulling it back up just to replace the bolts but I think that may be a waste of time as it's secure as of right now.
    I'm never happy with any pot I use (even a Drake) so I have a tendency to swap them alot to see if I find one I like better, which I know sooner or later this flange will break completely.
  6. hj
    quote; so I have a tendency to swap them alot to see if I find one I like better,
    Are you that guy who has a row of old toilets along the side of his property instead of a hedge? I hope you realize that the SEAT is what makes a toilet comfortable, NOT the ceramic bowl.
  7. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    I would try heavier screws to fasten the flange to the floor and then a flange repair plate on top to hold everything in place
  8. gusherb94
    gusherb94 Member
    Jan 13, 2009
    Everything
    chicago/nw IN
    Haha absolutely not. And I have a seat I like.
    I need to save up and just get a Drake II, only thing is I don't like that they only come in ADA height.
  9. Terry
    Aug 17, 2004
    [​IMG]
    If it's just hold the closet bolts to the floor securely, this works.
  10. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    So try an Aquia. They come in both ADA and non-ADA height.
Similar Threads: Reparing Unlevel
Plumbing Forum, Professional & DIY Advice Preparing for inspection... Jul 20, 2006
