I have a 3/4hp Goulds submersible that I removed from my well because the pressure had significantly dropped. The motor is still fine but it was used to supply a water sourced heat pump for the 7.5 years it was in service so has pumped a LOT of water. It was suggested by a plumber that it would be worth repairing since the motor is still in good shape. He indicated that the impellers often break away from the shaft resulting in reduced head and these can easily be replaced.
Yeah, I know there are proabably an number of factors to consider here but in general is it even worth considering repair of a pump this age?
