Hi, hoping someone here can offer some quick advice.
I'm air-testing a new PVC DWV system in our house addition (our county requires 5psi air for 15 min for the inspection). In 15 min the pressure goes from 5 psi down to about 4.2 psi, so I've got at least one leak.
I've found one leak so far, in the vent stack in the attic. The fittings are kind of close together in the area of the leaking fitting. When I cut out that fitting to replace, it will leave me with just a small section of straight pipe to fit a new san tee. But since I'm cutting it close, the part of the pipe the tee will fit on already had primer on it, and possibly some cement, on it from when I first assembled the fittings.
Will some cement on the pipe prevent me from getting a good joint with the new fitting? Will just having swabbed primer on the area be a problem?
I guess what I'm asking is what's the best way to prepare the pipe for the new fitting assuming it previously had primer, and possibly cement applied to it. I don't want to replace the leaking fitting only to find the replacement also leaks!
If I go back far enough from the leak to get clean, untouched pipe, that will mean replacing 4 fittings instead of 1... obviously would like to avoid this if at all practical.
Thanks much for any advice.
Keith
Keith
