Repairing gas pipe covering
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rdtompki, Jan 13, 2007.
  1. rdtompki
    rdtompki New Member
    Dec 21, 2005
    Iowa
    I've got an underground gas line that is the variety with a yellow coating. Trenching by hand for another line the coating got a bit nicked up in places. What's the proper procedure for repairing the coating?
    Rick
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    If it is yellow, it might be just a plastic pipe - We use plastic pipe underground all the time...
    If it is plastic there whould be a tracer wire on the pipe...
    If this is the case you might want to have someone come out and look at the pipe to ensure you did not damage the pipe itself...
  4. rdtompki
    rdtompki New Member
    Dec 21, 2005
    Iowa
    The pipe is definitely iron and has probably been in the ground for 15 years. Appears to be in good condition, but I have nicked some of the yellow plastic sheath. Where this pipe rises out of the ground at the pool heater the covering is split and the iron pipe underneath is somewhat rusted.
    Rick
  5. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I guess I've just never been around gas much but recently had a propane tank installed and the installer used 1/2" soft copper which has a yellow sheath over it. If you're reasonably certain that the pipe is not compromised you could just tape it up really good or use a neoprene coating painted on. A product is sold called Liquid Tape which is pretty good for things like that...or you could put a good gob of roofing cement on it.... Silicone would probably work also.
  6. Phil H2
    Phil H2 New Member
    Sep 12, 2006
    Tujunga, CA
Similar Threads: Repairing pipe
Plumbing Forum, Professional & DIY Advice repairing leak on older/smaller copper pipe advice wanted Apr 22, 2014
Plumbing Forum, Professional & DIY Advice Repairing/replacing leaky copper DWV pipe Sep 9, 2013
Plumbing Forum, Professional & DIY Advice Fill void under foundation when repairing drain pipe? May 30, 2013
Plumbing Forum, Professional & DIY Advice repairing a section of cpcv pipe Jan 7, 2010
Plumbing Forum, Professional & DIY Advice Repairing Sewer Pipe from inside Feb 2, 2008
