repairing a section of cpcv pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by huliman, Jan 7, 2010.
  1. huliman
    huliman New Member
    Jan 7, 2010
    Colorado
    :confused: After cutting out a section of FlowGuard cpcv pipe with a leaking elbo attached to a T, how do I re-insert the new section into the new sleeves on the ends of the two sections from which it was cut? It doesn't seem like the pipe is flexable enough to bend and angle it into the sleeve. Do I apply the cement on both ends, try to fit the pipe into the sleeves and position it all at the same time?
  2. hj
    pipe
    You cannot repair ANY pipe without being able to move the two sections apart far enough to insert the repair, either by flexing them or spreading them. If you cannot move the two ends you either need to use a union or multiple fittings to create a means of fitting things together. DO NOT try to insert the pipe into a fitting, and then pull the fitting back onto the other side.
Similar Threads: repairing section
Plumbing Forum, Professional & DIY Advice Repairing thread damage in pool valve connector Sep 19, 2016
Plumbing Forum, Professional & DIY Advice Repairing a pinhole leak in old black plastic water main. Jan 25, 2016
Plumbing Forum, Professional & DIY Advice Repairing leak in PVC DWV joint Nov 5, 2015
Plumbing Forum, Professional & DIY Advice Replacing/repairing hose bib--cant remove stem Mar 31, 2015
Plumbing Forum, Professional & DIY Advice !!Low/No pressure from hot water heater after repairing pipe-PLEASE HELP!! Feb 19, 2015
