Repair to fancy sink trap ensemble
Mahnrut
Maryland
Hello
I hope someone can advise. We have a 3 year old italian Cono sink (8010/R) with a pop up drain which has been damaged so no longer closes. We don't need this drain to close and would like to replace it with a regular grid drain assembly. We do some plumbing but are not sure what would fit since it is european.
Any advise much welcomed. The original chrome on the ring around the sink opening has pitted even though this sink is rarely used so we are not eager to pay the big bucks to get another one like it anyway. Thanks
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Maybe not Terry.
Some of those Euro fittings only fit each other.....
Is the bottom pipe above the Euro PTrap the same size as 1 1/4" stainless pipe?
Maybe not Terry.
I'm referring to the lav on the wall.
That's standard. If you pull the drain assembly, you can replace it with any standard lav drain.
Right now, they have a bottle trap for a p-trap. That might be reusable, or if not, a 1-1/4" P-trap
Mahnrut
Maryland
Thanks for all the replies. Much appreciated. When we took it apart and cleaned it all up of the calcium deposits we saw that the cap top unscrewed so in future we can keep the crud off without having to force the cap up. But having done that the stopper now seals and as I think that we would have to replace the whole lot (and it was several hundred dollars) we are keeping it for the time being. That being said we saw a lot of bad pitting of the chrome where it joins the porcelain and only after 3 years and little use so I would hesitate to spend the over $300 on this Nameek drain set up again. What we did notice was that the drain did not have an overflow hole although we purchased it all together with the sink. Apparently the plumber did not notice when installing either. We have put it back together hesitating to make a hole in the drain for any overflow water to drain into not knowing exactly how to gauge where to drill this. Thanks again.
JohnfrWhipple
North Vancouver, BC
Many European sinks have no overflow - the European bathroom's build with secondary back up drains because of this.
There are two types of sink kits to order. One with an overflow and one without an overflow.
Not sure you can simply drill a hole in your old one - there might be more to the overall design.
