Repair/Replacement Options
Discussion in 'Water Softener Forum, problems, installation and r' started by SuperAcer99, Dec 26, 2011.
  1. SuperAcer99
    SuperAcer99 New Member
    Jun 1, 2010
    Arizona
    Hello,
    I have a 16 year old 32k grain water softening unit with a Fleck 5600 Econominder Valve on it. The basket/screen on the end of the tube in the resin tank cylinder broke sending resin breads throughout the pipes in the house. I had a plumber come out earlier today to unclog the pipes and clear the faucets, toilets, shower heads etc as well as replace the ball on the Fleck 5600 valve because there was water leaking from it when it was in bypass mode. The timer on the Fleck 5600 was replaced recently so I think the whole Fleck unit itself is in good shape now, but the tube and resin in the cylinder tank need repair or replacement. I don't want to spend $1000 on a whole new complete assembly, especially since I don't know if I am going to stay in the house I am in for a long period of time. I would appreciate it if you all could give me some suggestions on some cost effective repair/replacement options?
  2. Gary Slusser
    Retired
    What ball on a 5600?
    Replace the distributor tube with a new one including the bottom basket and the resin. A ":32K" is a 1.0 cuft and has a 9" x 48" tank.You can get both online or from a local dealer or plumbing supply house. Shop the prices you get; expect somewhere around a max of $100 for the resin and $20 for the DT.
Similar Threads: Repair/Replacement Options
Water Softener Forum, problems, installation and r Trying to choose between water conditioning options Jun 24, 2016
Water Softener Forum, problems, installation and r Iron Filter Backwash/drain Options Apr 30, 2016
Water Softener Forum, problems, installation and r Oversized softener, options to increase efficiency (Clack WS1)? Jan 23, 2016
Water Softener Forum, problems, installation and r Recomandations for some options for a 5600 SXT softner Feb 10, 2014
Water Softener Forum, problems, installation and r Softener drain in crawl space - options? Jan 31, 2014
