BarbD
Novice here would appreciate any help on repairing a leaking Kohler pull-out kitchen faucet.
The faucet leaks a bit from under the handle. I've removed the handle and the flange (?) to expose the top of the cartridge. I removed a small screw from the top of the cartridge and tried to pull it out, but something -- a clip maybe -- is holding it in. I've tried to pull the whole sleeve and attached spout up off the unit to see if there is a clip underneath, but it stops after about half an inch. It feels like the hose from the pull out spout is preventing the whole thing from coming off, but not sure that's the case.
So the cartridge won't pull out and the sleeve/spout won't pull off, and I can't reach any rings. Not sure what to do. Any suggestions?
Thank you.
Thank you.
