Removing Water Softener - capping connections
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bobwood, Mar 2, 2008.
  1. bobwood
    bobwood New Member
    Mar 2, 2008
    We've moved to city water and have removed our Water Softener. I now have two open pipes (input and output) with a sliding shutoff valve. The sliding plastic bypass/shutoff value leaks slightly. I'm looking for a quick solution that does not involve cutting and soldering. Is their such a thing as a male end cap to plug the lines? Picture is attached. Thanks in advance for any help!
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    A quick fix would use shark bite caps. You will need to cut the pipe tho.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    You could also cut out the unneccessary stuff and run a nice new pipe.
  5. bobwood
    bobwood New Member
    Mar 2, 2008
    I've got a tubing cutter but am crappy at soldering (I've done it a handful of times but need more practice). I've been using compression fittings for some recent work and saw the SharkBite stuff but did not know how it worked. Thanks!
  6. Gary Slusser
    Retired
    You should check the water company's web site for their water quality report and find out how much hardness they have, and reinstall the softener if there is more than 3-4 gpg of hardness in your water.
    That by pass valve is repairable. It is probably a Taras, I think that's the name of the manufacturer, and the 4 orings cost next to nothing. One end knob unscrews from the shaft that has the orings on it
Similar Threads: Removing Water
Plumbing Forum, Professional & DIY Advice Removing the water supply line on a kitchen sink Nov 16, 2014
Plumbing Forum, Professional & DIY Advice Removing soldered water pressure regulator? Nov 16, 2014
Plumbing Forum, Professional & DIY Advice Removing a water line to a non-existant ice maker Nov 2, 2010
Plumbing Forum, Professional & DIY Advice Removing water from P trap/drain Aug 14, 2006
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
