Removing tub spout and drain
Discussion in 'Shower & Bathtub Forum & Blog' started by Lloyd, Mar 8, 2005.
  1. Lloyd
    Lloyd New Member
    Mar 8, 2005
    I am trying to replace old tub spout and drain in a one piece fiberglass tub and shower unit. When I try to unscrew the old Delta spout with a wrench it is obvious it will take a lot of force to turn it. I fear breaking something in the wall and/or the spout itself if I really force it. Any ideas?
    Secondly, what sort of tool does one use to remove the drain from the same unit? Should I just call a plumber for these problems???
  2. jadnashua
    Some spouts are held on with a set screw - don't know about yours. Did you check underneath it for one?
  4. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Jim's right. Some spouts have an allen head set screw on the underside. Some you just unscrew like a big nut. As a personal preference, I like the slip on spouts with the set screw. Makes for easier install initially and removal later on. As far as the drain goes, there is a tool we call a "dumbell" around here. It slips inside the drain and locks on allowing the user to either insert a screwdriver through it to turn or use a 10 or 12" adjustable wrench for turning. You can find these at most plumbing supply houses. Not sure about the big box stores. Getting the new drain started in the drain shoe can be a booger so be patient so as not to strip the threads. Strip them and you'll be kicking yourself in the tail. When you change out the drain assembly you might want to change out the gaskets between the drain shoe and the tub also (on the underside of the tub).
    Good luck
    [​IMG]
  5. hj
    spout
    If the spout is screwed on, then if it breaks for you, it would probably also break if a plumber tried to remove it.
Similar Threads: Removing spout
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Removing Difficult Tub Spout May 26, 2015
Shower & Bathtub Forum & Blog Removing Tub Spout Aug 30, 2008
Shower & Bathtub Forum & Blog Removing Price Pfister Tub Spout Jun 27, 2008
Shower & Bathtub Forum & Blog Removing old Delta spout / diverter Sep 9, 2007
