Removing the water supply line on a kitchen sink
Manisha Patel
Illinois
I was able to unscrew the bolt/nut, but was not able to remove the tubing from the water supply line. I pulled and pulled and it would not come out. This was my first plumbing job and I am afraid I might have to call in a professional, simply because it would not come out. Do anyone have a suggestion? Thank you for any help you can provide.
Post a picture of what you're talking about to ensure a reliable answer.
Manisha Patel
Illinois
Manisha Patel
Illinois
Hi there,
Thanks for the idea. To save time, I found a pic online. After loosing the bolt/nut, I can not remove the line that runs from the faucet to the shut off value. I pulled and pulled. This sink was put in the early 90's. I have everything figured out and can get the job done but this snag. I am thanking you for any help you can give me.
Unless you have a metal or plastic tube supply line, it is not inserted into the valve so it should come loose by twisting it sideways. If you have a metal supply line you have to bend it in the middle to remove it.
If you have muli-turn valves (angle stops) you should consider replacing those with 1/4 turn valves. The 1/4 turn units are ball valves, and they are less likely to leak or seize.
And if you are replacing the faucet anyway, you could just cut the line going to the faucet if that line does not come free readily.
If you have the valve shown in the drawing, I think that is a compression connection valve. A good photo could show what you really have.
