Removing the Casing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mrjaybov, Jun 17, 2009.
  1. mrjaybov
    mrjaybov New Member
    Apr 29, 2009
    I have my casing down to where I want it and have dropped my point. Should I pull the entire casing out or just a few feet above the point?
    We are talking about 25 ft of casing....
    Or do something entirely different...
    Any advice on how to remove or lift it easily... I was considering a jack of some sort ot help me lift it.
    Thanks in advance for your advice.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Do you mean to say, you have just thrown a point down the casing with nothing on top of it?
    Some people wash in a larger pipe, drop the point with a smaller pipe attached to above ground, then pull the larger pipe leaving the point and smaller pipe to pull water from.
    When you drill a real screened well, you can drop the screen down the hole, with a k packer or just a blank then pull the casing up off the point exposing the slots to the aquifer. The blank and k-packer stay in the casing or you can use a bremer check to seal off the screen to the casing.
  4. mrjaybov
    mrjaybov New Member
    Apr 29, 2009
    No, my casing is 4 inch and my point and pipe (attached) are 2 inch. They are just resting inside the casing for now, I haven't attempted to move the casing upwards to expose the point to the aquifer.
    This is just a small back yard well, so my wife can water her garden...
    Should I pull the casing up enought to test my seal for leaks?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    What seal? I guess I don't totally understand what your doing.
    If you put in 4" and lowered a screen down on 2" pipe, you can pull the 4" all the way out as long as the screen stays where you think the vein is and you have 2" sticking out of the hole when the 4" has been pulled. Now you have a two inch well.
Similar Threads: Removing Casing
Pumps and Tanks Well Forum & Blog. Water is life. Removing sand from 32' dug well Friday at 6:41 AM
Pumps and Tanks Well Forum & Blog. Water is life. Removing QD Pumptec Nov 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Removing well pit Apr 14, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Removing separated injector from jacuzzi 1/2 shallow well Oct 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Removing broken plastic injector from shallow well pump Oct 19, 2015
