Removing sprinkler heads
Discussion in 'Irrigation / Sprinkler Forum' started by JennM, Jun 8, 2011.
  1. JennM
    JennM New Member
    Jun 8, 2011
    Colorado
    I'm wanting to make some changes to the postage stamp sized backyard of my condo. I'm planning on taking out all the grass. I want to install two raised garden beds, surrounded by gravel in the 6 x 18 strip across the back, and then extend the patio out the additional 6 feet of space that's left to the side (only half that space is lawn right now).
    The problem is what do I do with the sprinkler heads? Especially the two where I want to extend the patio. All of the lawn care is handled by the condo association and the sprinklers for all the units are connected. I know nothing about sprinklers so I'm at a loss, and I don't trust the lawn care people the association has hired to run things. Please help.
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    The best thing to do with the heads you want to elimenate is dig down to where each head is connected to the white pvc pipe, unscrew the fitting and replace it with a 1/2 inch threaded plug being sure to use teflon tape to seal the threads. For the raised beds you can convert the fittings to move the heads to those boxes or change them to drip lines or micro-sprays according to what you want to plant.
Similar Threads: Removing sprinkler
Irrigation / Sprinkler Forum Need Help Removing Impeller from Goulds JS+ pump Jan 25, 2010
Irrigation / Sprinkler Forum drain valve and removing water Jul 7, 2008
Irrigation / Sprinkler Forum Sprinklers worked, now not at all. For no apparent reason. Mar 11, 2017
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
