removing single handle shower faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dde, Aug 10, 2007.
  1. dde
    dde New Member
    Aug 7, 2007
    hi. i'm trying to remove my shower handle. i already removed the small allen screw but i still can't pull it out. is there anything else that i need to take out? thanks!
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    All depends on what show handle you have but most of the time it takes a good pull, you normally have a billed up of lime.
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Oh, wait....lets be clear on terminology...
    The "handle" is the chrome or brushed nickle finish handle...the "stem/ cartridge" is the actual working part of the valve the handle is attached to.
    If your only taking the "handle" off and it's a moen...DON'T pull that clip!
  5. hj
    Moen
    Unless you remove the handle and stop tube, you can't even get to the clip. If it is a Delta lever handle shower valve, then the handle can corrode to the round stem on the ball. If so, you have to rotate it while pulling on it.
Similar Threads: removing single
Plumbing Forum, Professional & DIY Advice Removing single handle faucet Dec 28, 2004
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
