Removing saddle valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by malkajef, Apr 14, 2005.
  1. malkajef
    malkajef New Member
    Apr 14, 2005
    Decades ago, a plumber used what looks like a self tapping saddle valve to connect my refrigerator's ice-maker's water supply pipe to the main cold water pipe under the sink. Now the saddle valve is leaking from the self-taping screw. If I turn this screw just right, I seem to be able to stop the leak though I do not know how long this will last. Any little twist of the screw and the saddle valve leaks again.
    How do I repair this leaking saddle valve?
    Thanks.
  2. hj
    valve
    Remove it, cut the pipe off near the hole and install a new valve for the faucet. Use a two outlet valve with the proper sized openings for the sink and icemaker. Probably 3/8" and 1/4" compression. As long as the hole in the pipe is inside the valve socket it will not leak.
    [​IMG]
  4. malkajef
    malkajef New Member
    Apr 14, 2005
    Thanks for the quick reply.
    I am not a plumber, so cutting the pipe, etc. is beyond my capabilities ....
    Is there a simpler way to repace the saddle valve? Do they exist with "larger" tapholes or some other way to plug it for good?
    (My temporary twist of the saddle valve is not holding. It is leaking again through the tap screw hole). Should I bite the bullet and call a plumber?
    Thanks.
  5. TonyBagadonutz
    TonyBagadonutz Electrician
    Mar 24, 2005
    Electrician
    NJ
    I'm not a plumber either...but I was able to removal of a leaky saddle valve. Mine was for a deceased humidifer on my furnance. Here's what I did:
    - shut off off the water
    - cut back the pipe with a tubing cutter
    - drained the water from the pipe by pulling it down a bit
    - put a real valve in (ball cock)
    - put a short 12" nipple(dead man) on that
    - soldered the thing up (clean w/emory and apply flux before soldering)
    - put a cap on the "dead man"
    Now when I buy a new humidifer, I can put the saddle on the dead man...if it ever leaks, I shut off the valve, remove the bad saddle, cut out that one inch of pipe and recap it. Done. I could do it about 12 times before it ever became a real issue again.
    All told, it took me maybe an hour to do.
    I have seen some putty that is *supposed* to seal a pipe - but I have no idea if it will actually hold for any duration of time or if it is just a band-aid.
    If you are able to get in there and do the work, or lack the ability/confidence to do the work...call a plumber.
    Side note: Do not use duct tape to try and seal it. I was over at my MIL's the other day..turned on the outside faucet and was given an unwelcome shower. Apparently, the pipe had burst at some point (from freezing) and the solution was duct tape. Sure, it held for a few years (judging from the layers of paint on the tape)..but it "blew" at a bad time - fortunately, I was there at the time otherwise who knows how long the thing would have ran for?
  6. PEW
    PEW DIY Senior Member
    Suggestion, if it is beyond your capabilities it would be well worth your investment to have a plumber come in and do the installation for you. Saddle valves will always create a problem, it is just a matter of time.
    Paul
  7. malkajef
    malkajef New Member
    Apr 14, 2005
    Solved
    I think I solved the leaking Saddle Valve problem. I tightened what I believe is called the packing nut (around the self taping pin) and that stopped the leak. It was already tight but apparently not tight enough so that the extra tightening seems to have done the trick. Can't really blame the saddle valve. I figure it was installed a little over 30 years ago!
    Good thing too, because the pipe cutting and soldering is beyond my equipment and ability and I was just about to call a plumber but decided to try this final thing.
    Thanks everyone for all your help and hand holding.
  8. malkajef
    malkajef New Member
    Apr 14, 2005
    I may well still do that, but at least now it will not be as an "emergency". Thanks for the advice.
  9. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Saddle valves arent allowed by code here though "installers" from the appliance stores install them all the time. The piercing needle will rust out and the valve itself will leak. I replace these junk valves on what seems like a daily or every other day basis using either a two outlet stop as HJ suggested or a 1/2" sweat X 1/4" compression stop.
    Good luck
Similar Threads: Removing saddle
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Removing Old Tub Spout Jul 29, 2016
