removing rusty drain from antique sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by peeler, Oct 30, 2009.
  1. peeler
    peeler New Member
    Oct 30, 2009
    Kannapolis, NC
    I'm restoring a 1923 Kohler pedestal cast iron sink,, and having a bit of trouble
    removing the drain pipe. There is rust between the pipe and sink body. I've been hitting it with spray oil periodically, tapping it with a hammer. I'm assuming the visible flange ring is attached to it permanently but not sure...
    any ideas? would a little heat be effective, safe?
  2. hj
    drain
    Cut it off with a hacksaw, or SawZall. Heat could cause the enamel to chip off. The exposed piece is part of the drain, not the sink.
  4. Master Brian
    Master Brian DIY Senior Member
    Nov 13, 2008
    Kansas
    I'd be worried the sawsall would vibrate and chip the enamel as well. Any chance you have a dremil or a diegrinder/cutter? If you try the sawsall, use a good sharp blade....
    A little heat would probably get it off, but like HJ said, it could pop the enamel. I think I used a diegrinder to cut the one off my antique clawfoot tub!
  5. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    If you have the sink out just simply cut the drain off with a hacksaw as close to the underside of the sink as you can. Make sure you cut/pry off the nut holding the drain in place.
    Good luck!
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    A dremel with a sharp wheel works also. Cut the nut,
  7. hj
    saw
    There is NO vibration from a SawZall that would damage the enamel. WE do it all the time. But you have to cut it off under the sink, not on top.
Similar Threads: removing rusty
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Removing Old Tub Spout Jul 29, 2016
