Removing Purple Primer Drip (oops)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by fishbum, Nov 17, 2005.
  1. fishbum
    fishbum New Member
    Oct 6, 2005
    California
    Ok, how do I remove the drip of purple pvc primer from my new white shower?
    I know, I know - slow down you say. But no matter what I did a drop of the stuff always fell from somewhere...
    thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Well for future work take plastic sheeting and tape and mask off the are below where you are working. As far as the drip you have now anything you do will most likely marr the finish, that said try taking a Q tip and put it in clear primer, lightly rub the spot and keep changing the Q tip, that might work but I have never tried it so I am not sure.
  4. fishbum
    fishbum New Member
    Oct 6, 2005
    California
    Phew, gotcha.
    I was plumbing a drain line that runs between the joists above the shower.
    Lesson learned - I already covered the upstairs shower with plastic as that is where the drywallers will be working tomorrow!!!!!!
    thanks
  5. fiasco
    fiasco New Member
    Nov 14, 2005
    After getting the drip off you might try using a car buffing wheel and some rubbing compound to smooth the finish if it is marred. I had alot of success with this when I had to remove a very shallow chip when a piece of ceramic was dropped into my tub.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    paint thinner- turpertine
    try paint thinner or turpentine, possibly acetone
    we ruined a vinly floor years ago that way, ae right into the
    finish and we ended up replaceing it....
    I wont have the purple stuff on the job anymore..
  7. fiasco
    fiasco New Member
    Nov 14, 2005
    Acetone will eat plastic. I don't know about the finish on a fiberglass tub but I would be hesitant to use acetone.
  8. fishbum
    fishbum New Member
    Oct 6, 2005
    California
    The drip is a long streak, about 1/16" wide and 4" long down on the front of the threshold... if I get time this weekend I'll give a few of these ideas a try.
    Thanks everyone-
  9. hj
    drip
    Now you know why we do not install the showers until after all the piping is done.
    MichaelBukay likes this.
  10. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Try toothpaste
    I got a spot off a molded countertop using toothpaste (not the gel) on a cloth. It has a little very fine abrasive that didn't mess up the finish.
    Stephen Strong and taterbug like this.
  11. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    I spilled bleach on the carpet once and homeowner’s insurance paid for a nice new wood floor. You might consider turning it into the insurance company.
  12. fiasco
    fiasco New Member
    Nov 14, 2005
    I wouldn't turn something that small into insurance. They hold that against you and may drop you when you have to file a real claim. Further, if I were to buy a house the first thing I would do is check previous claims as insurers will hold the previous occupants claims against you when calculating your premiums.
  13. rshackleford
    Oct 18, 2005
    The claim might not be that small. The insurance might pay to replace the entire shower. Why have insurance if you aren’t going to use it?
  14. Daryl
    Daryl Handyman
    Nov 18, 2005
    Handyman
    Central Ohio
    If this drip is located on the outside face of the threshold face you might have a chance if it located on top of the finish. I am assuming the showerpan is acrylic or cultured marble. Go to the nearest auto paint supply store and pick up one of the little round rubber sanding discs which most carry. These are about 1 1/2 inch in diameter and use little adhesive backed sanding discs. they come in very fine grades and are easily controlled do to the size. Purchase 1000 or 1200 grit discs and a squeeze bottle of polishing compound. Very carefully and slowly sand over the drip using water for a vehicle. (Sandpaper is wet or dry). You are attempting to remove just the high part of the drip down to the clear coat finish on the surface. Once you have carefully removed the primer you can polish the fine sand marks out with the polish and a soft rag. THese acrylic and cultured finishes have a clear coat and top of the color which allows small imperfections to be removed and protects the color from wear and tear. (This system is used in the car industry to remove small flaws from urethane finishes.) :D
  15. arrowboy
    arrowboy New Member
    Apr 2, 2011
    Huntington, Ohio
    Tooth Paste works like a dream, I never would have thought of it. The primer was on the tray for about 2-3 hours, but it came right off. Thanks!!
  16. taterbug
    taterbug New Member
    Feb 16, 2015
    Florida
    Toothpaste worked!!! My husband dripped the primer in a few places on our new bathtub. Didn't mess with the finish. The drips were there for a few days. Yay!!!
    Stephen Strong likes this.
  17. jadnashua
    There was a comment about never using the (tinted) purple primer...some inspectors want to see that to ensure you actually used a primer which is nearly impossible to do if you use the clear stuff. The stuff is nasty, and stains. Good to know that toothpaste can remove it, at least from some surfaces.
  18. kevinkay
    kevinkay New Member
    Jan 1, 2010
    Massachusetts
    Barkeepers friend (its like comet for metal) worked for me removing dried purple primer from a white porcelain tub.
    This stuff is hard to find, old time hardware stores carry it - its FANTASTIC for pots and pans and whenever nothing else works this stuff comes through.
  19. JerryR
    JerryR Member
    Jul 27, 2011
    Florida
  20. QueBall
    QueBall New Member
    Jan 31, 2013
    Edmonton, AB
    I have a local acrylic and fibreglass repair guy who can rebuild chips, scratches, and even big chunks taken out of a shower base. If the home remedy didn't work I would have him out. His cost is very reasonable.
    There are also DIY repair kits in colour matching kits for different big brands.
    http://www.surface-repair.com/factory-color-paste-by-brand/
    [​IMG]
    [​IMG]
  21. Stephen Strong
    Stephen Strong New Member
    Nov 10, 2016
    Spilled the purple primer and this was the first site I came across. So before I jumped to and heavy duty stuff or sanding this problem out, I seen someone posted toothpaste. Figured what's the harm in trying it first, if it doesn't work no harm done. Well after picking up some regular crest toothpaste and a toothbrush and scrubbing in circles for an hour and a half I managed to get the stain out completely and used some spray on liquid wax for like a car type made it all shiny again like it never happen. Side note the darker it is stain the harder it will be to scrub out. DON'T USE THE PURPLE SHIT use the clear primer.
    Hopefully this help whoever makes the same mistake in the future. I have pictures of before and after I was done.
Similar Threads: Removing Purple
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Removing Old Tub Spout Jul 29, 2016
