Removing old Delta spout / diverter
Discussion in 'Shower & Bathtub Forum & Blog' started by billwil, Sep 9, 2007.
  1. billwil
    billwil New Member
    Sep 9, 2007
    Product manager
    Hartsville, SC
    Shower enclosure in guest bath has old Delta system (20 years old?) with two handle controls and spout with diverter. Would like to replace spout (along with showerhead) but it does not appear to be threaded. If compression fit, how do I remove? There is small opening at base near wall that allows access to pipe but there is not a set screw in it. Suggestions appreciated - thanks.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Delta has a design where a threaded adapter is soldered to the copper pipe, then the spout just screws onto that adapter. Are you sure you can't unscrew it?
  4. billwil
    billwil New Member
    Sep 9, 2007
    Product manager
    Hartsville, SC
    Jimbo - I've turned it with some force and didn't seem to budge but I didn't want to over-do it. Is it most likely threaded?
  5. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Strap wrench.
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    whom ever installed it could have cranked it hard, also make sure there is no caulking holding it at the wall. Most tub spouts are attached with a nipple or copper male adapter. If there is no set screw the installer cranked it. I've had some very difficult ones in the past, thought i would rip out the whole valve.
Similar Threads: Removing Delta
Shower & Bathtub Forum & Blog Help removing Delta cartridge, and is my water actually off? Feb 19, 2015
Shower & Bathtub Forum & Blog Removing water saver / restrictor from Delta shower wand..... Oct 31, 2009
Shower & Bathtub Forum & Blog Delta Monitor - removing assembly rp19805 Jul 2, 2009
Shower & Bathtub Forum & Blog problem removing delta faucet in bath Dec 23, 2006
Shower & Bathtub Forum & Blog Removing Delta tub spout Jan 26, 2006
