Removing Low Flow Restrictor on Kohler Showerhead
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Nov 12, 2013.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    I removed the o-ring off the restrictor that was under the debris screen.
    I tried gently but the green restrictor part does not budge easily - hence the post.
    I'm not sure how Kohler got it in but is there any way of removing it without destroying it ?
    [​IMG]
  2. chefwong
    chefwong Member
    Jun 14, 2006
    I ended up drilling it out in a attempt to drill and then remove the green part in-whole.
    They have really got it put in. It's thick gauge plastic....that won't bend easily with a pick or needlenose plier.
    I removed as much as I could - cleaned it up with a round rasp (and even used a coarse round rasp very carefully) as the plastic is that thick !
    I'm sure I might have had better results if I was do it on the ~knuckle~ side, but I would not see a easy means of removing the head cover....and I did not want to mess with the finish that much doing any prying.
    Removing these on the Grohes is a walk in the park compared to this one
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I skipped by this, but can't resist. Why do you think you need more water than the legal amount?
  5. Terry
    Aug 17, 2004
    I use one of those shower heads, but I can't remember if I left the restrictor in or not. Sometimes my son James will remove them on installs.
    They are pretty nice shower heads.
  6. chefwong
    chefwong Member
    Jun 14, 2006
    For stronger water pressure.....of course
    It's all relative I suppose.
    Dishwashers take 2hrs to complete a cycle these days. Non phosphate powder cleans like crap...
    So I use less water but more electricity ...
    I've had my Miele guy go into the ~service menu~ on my laundry machine and increase the water level of the machine.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Hate to tell you, but water pressure does not increase by removing the flow restrictor. What is it you are removing? It's the FLOW restrictor, not a pressure regulator.
  8. Terry
    Aug 17, 2004
    Gary,
    Drilling or removing the restrictor does let the shower head dump more water. It seems like more pressure. :)
  9. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Drill that sucker out and enjoy your shower!
  10. jadnashua
    This all assumes you have a big enough WH and the pipe sizes are sufficient, otherwise, it won't help much, or at least for long.
  11. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Dishwashers take longer now because they spend a lot of time soaking the dishes; they really don't use more electricity because the pumps aren't going full blast during those two hours. If you use the 1HR cycle like we have on our new Kenmore Elite dishwasher (amazing quality and performer), you use both more water and more electricity than on the 2.5 hour cycle Smart Wash.
    Anyway, we have found that Finish Powerball Tabs do an amazing job and are way cheaper than brands like Cascade. Better and cheaper -- a combo I like.
  12. chefwong
    chefwong Member
    Jun 14, 2006
    DW Powder is a whole nuther thread in itself ;-/
    Cascade Platinum or Finnish Quantum are priced fairly similar, but Quantum ethches certain glass in my brief testing...
    I'm still working off my stash of Phosphate DW powder.
    Fellow Plumbers, have you seen a SPIKE in dishwasher intalls/replacements over the past couple of years ?
    I can easily wonder how many consumers end up replacing their machine recently thinking it's just poor performaning, when the reality is - the current stuff on the market is just up to snuff, compared to the previous phosphate formulations..
  13. DDAANOS
    DDAANOS New Member
    Apr 26, 2014
    New York
    fibrous disk
    HI Terry, can you tell me what is the fibrous disk, that sits between the plastic water flow restrictor and the cone shaped mesh screen. I'm referring to the Kohler Flipside shower head. Thanks
  14. hj
    quote; Removing these on the Grohes is a walk in the park compared to this one
    Almost makes you think they did not want you to do it, doesn't it?
  15. Bill Shack
    Bill Shack 30years plumbing 10years plumbing inspector
    Mar 10, 2014
    retired
    montreal quebec Canada
    I use a large wood screw and screw it into the resistor then grab the screw head with a pair of pliers and pull. I alway remove the restrictor, but once i had a customer that asked me to put it back.
  16. ankhseeker
    ankhseeker Member
    Oct 2, 2013
    San Pablo, California
    Look out! Here come the water police ;-)
  17. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    They sure would be if you live in California.
  18. DDAANOS
    DDAANOS New Member
    Apr 26, 2014
    New York
    Does anyone know what the fibrous disk, that sits between the plastic water flow restrictor and the cone shaped mesh screen, is there for?. I'm referring to the Kohler Flipside shower head. Thanks
Similar Threads: Removing Flow
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Removing Old Tub Spout Jul 29, 2016
