Removing Leaded Closet Flange
Discussion in 'Toilet Forum discussions' started by JKriebel, Jun 23, 2006.
  1. JKriebel
    JKriebel New Member
    Jun 23, 2006
    Hi, I searched the forum for my situation but came up empty. When we moved into our house the second floor toilet was leaking for a long time which rotted the subfloor around it. The closet flange is leaded into cast iron. How do I best go about removing it from the iron pipe so that I can install the subfloor properly?
    A response would be greatly appreciated.
    thanks
  2. jadnashua
    Select a drill bit that is small enough to just fit between the flange and the pipe. Make a series of holes through the lead all of the way around - swiss cheese it. Then, take a screwdriver or something else that will fit in the holes and pry what's left of the lead out. Pick out the oakum packing, and pull it apart.
  4. hj
    flange
    Hammer and chisel applied to both sides where the bolt slots are located.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    HJ is right, that works best for me and it only takes about 60 seconds...............Just give it a good whack....
Similar Threads: Removing Leaded
Toilet Forum discussions removing leaded closet flange Oct 30, 2004
Toilet Forum discussions Removing crusted scale rings around rim holes? Dec 17, 2015
Toilet Forum discussions Repairing a PVC closet flange without removing tile Jan 15, 2015
Toilet Forum discussions Is there a way to replace closet bolt without removing the toilet? Dec 26, 2013
Toilet Forum discussions OT: Removing Spray Foam from Porcelain Oct 17, 2013
