Removing lead and oakum
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Marcus, Apr 14, 2005.
  1. Marcus
    Marcus New Member
    Apr 14, 2005
    Seattle
    Put this in the remodel forum, but I'm not sure where it should go -- sorry for the repetition!
    Greetings!
    I'm in the middle of a bathroom remodel and am replacing some DWV lines with PVC, to be joined with a cast-iron stack. My current bath/shower drain is 1.5" galvanized and I'm replacing it with a 2" line for a corner shower. I'm trying to figure out the best way to maintain 2" to the stack and was wondering how difficult it is to remove the lead/oakum in a 3" sanitary wye (what the existing 1.5" drain ties into).
    I've done a couple of searches and it seems like this shouldn't be too difficult, but I'd love to get some backup on that. I need to get the wye clean enough to accept a no-hub or a donut for new 2" drain.
    Any thoughts?
    Marcus
  2. TonyBagadonutz
    TonyBagadonutz Electrician
    Mar 24, 2005
    Electrician
    NJ
    The easiest thing may be to cut the cast at a point a few inches above or below the hub...then just attach a sheilded hub.
    I'm sure a "real" plumber could suggest a way to re-use the old hub...if at all even possible.
  4. Terry
    Aug 17, 2004
    With poured joints, the lead can be removed by drilling holes around the circle, and then prying out with a screwdriver.
    Sometimes a fernco insert will work. The rubber goes in the hub, and then the pipe slides in. A bevel on the end of the pipe and some liquid soap will help.
  5. Marcus
    Marcus New Member
    Apr 14, 2005
    Seattle
    Thanks Tony and Terry. I'm pretty sure these are poured joints I'll explore the drilling and prying, see what I come up with.
    Thanks again!
    Marcus
Similar Threads: Removing lead
Plumbing Forum, Professional & DIY Advice Removing lead closet bend? Mar 5, 2013
Plumbing Forum, Professional & DIY Advice Removing Lead/Oakum from cast iron - replacing tub/sink drain line - pics Feb 8, 2012
Plumbing Forum, Professional & DIY Advice Removing drum trap in lead drain May 2, 2008
Plumbing Forum, Professional & DIY Advice cast iron lead packed hub removing pipe Dec 3, 2005
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
