Removing kitchen sink drain
angieb12603
TEXAS
I need help! (obviously!) I am trying to replace a kitchen sink drain and it won't budge!!!:mad: I have managed to detach the pipe from the drain but the problem is the nut, or whatever it is called, that attaches the drain to the sink. When I try to turn the nut the whole drain turns. I have tried WD-40 and soaking it in CLR. I would much appreciate any suggestions even if it means removing the sink it self so I have more room to work on it.
Thanks in advance!
AngieB
Gary Swart
Yakima, WA
You might try using the handles on a pair of channel lock pliers through the top of the basket to hold the basket from turning when you turn the nut. It would take a helper to hold the pliers, probably with a screwdriver or other bar. This will ruin the basket, but if you're replacing it anyway, no loss. Yes, you can remove the sink now, but you'll still be faced with the same problem. At least now the sink is being held solidly while you work on it.
Randyj
Alabama
I've done the channel lock thing before too but the last few times I used two screwdrivers to form an X which I was able to use a board laid corner to corner in the sink or something long to hold it while I used a huge pair of pliers under the sink (could find that new fancy wrench I bought).
angieb12603
TEXAS
Removing sink drain
Thank you for your reply. A friend of mine helped me with that as well and it still turned but it was hard to get a good grip - didn't have a bar or good heavy duty screwdriver. I'll try that next. If you have any other suggestions in the meantime send them on!
Thanks again!
Happy New Year!
AngieB
Randyj
Alabama
hmmmm... hammer & chisel or dremel hobby tool with cutting disc. Not much else left.
angieb12603
TEXAS
Good idea on the x. At least I can try that if I don't have the extra pair of hands. The next step will be something that has a blade on it!!! :D
Thank you,
AngieB
Randyj
Alabama
I work alone and NEVER have help... always have to figure out how to do it ALL by myself. I have sometimes amazed myself what one person can do alone. I know a one armed carpenter who is about as good as I've ever seen.
Verdeboy
There are wrenches that are designed to install and remove basket strainers:
The basket strainer wrench holds the top part in place while the basket strainer locknut wrench unscrews the locknut. There are two types of locknut wrenches. You can buy these tools for under $15.00 at most decent hardware stores.
If that doesn't work, you need to cut off the locknut with a Dremel, using a metal cutoff wheel (wearing eye protection.)
angieb12603
TEXAS
Thanks everyone! This is the first time I have ever tried posting a problem and it is wonderful to have all of the suggestions. All of you have had some super ideas and today is the day. I will post how it all comes out!
Thanks again!
AngieB
Randyj
Alabama
U R Welcome angie. I started out in this business just doing handy man repairs for my mom's rental house and didn't have all the fancy wrenches. I still resort to my "figuring it out" methods out of habit rather than spending a little money for tools that I don't use very often.... and probably couldn't find when I needed them.
I use a hacksaw too. I always have one handy, and it takes about minute to cut the threaded ring off. Just angle the saw so that it cuts into the basket threads, when you have cut off a section, the rest will just snap off. The metal tends to be very soft stuff anyway.
This one was cut with a sawzall and metal blade.
Randyj
Alabama
Cass... I assume you drill thru the side of the basket nut to cut it into. Is that correct?
angieb12603
TEXAS
Thank You Everyone! I did it. I ended up using the hacksaw and cutting it at an angle. It took a little muscle but it worked and I have a new drain! Thanks for all of the suggestions. I am sure that this site will be very useful to me in the future as I am always looking to do something different to my house. I also have recommended this site to a friend and they have already registered.
Thanks again!!!! :p
AngieB12603
Randyj
Alabama
Great site Angie... I posted it on my lake community forum for all my forum buddies there... I'm sure it will generate lots of business... and might even help Terry sell a few Toto's... (I do accept commissions & referral fees!!!!):)
Flipper99
Princeton, New Jersey
Removing Sink Drain
I too had trouble removing the sink drain because the basket assembly was spinning with the large nut. I did not have a Dremel handy to cut the nut so I used a drill and drilled several holes (next to each other) into the nut. The drill bit was something less than a quarter inch. I then used a hammer and screw driver to connect the holes and pry the nut off. I am sure the Dremel with a cutting wheel would be a better way to go but this worked pretty well.
drain
Use a SawZall and cut the drain assembly right below the sink. When they installed the strainer they were sloppy and got putty, or caulking, in the threads of the nut and it has bonded it to the drain.
