removing Grohe cartridge
Discussion in 'Shower & Bathtub Forum & Blog' started by deew, Feb 5, 2005.
  1. deew
    deew New Member
    Feb 5, 2005
    Is there a trick to removing the cartridge from the Grohe tub filler valve and diverter? Need to remove the cartridge before sweating, but can't get it out. Thanks.
  2. jadnashua
    I've only removed a faucet cartridge, but assuming it is similar, there was a metal ring at the top with two screws. Just remove the two screws and the whole thing pulled straight out. You may find it helpful if you look at the parts blowup diagram. If you didn't get one with the valve (or lost it), then they are available on-line on the www.grohe.com site.
  4. ratanshah
    ratanshah New Member
    Feb 27, 2010
    Jeannette, PA
    Remove
    It is not easy but possible
    Once you succesfully unscrew the cartridge you will have to wiggle it loose with pair of plyers
    If too hard to unscrew use any home depot or lowes product for loosening
    ratan
    ratanshah@comcast.net
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Should I use the Estwing Hammer I bought at Lowes or, the Pick Axe I bought at Home Depot?
  6. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    This is a difficult task, and grohe doesn't provide you with the proper tools to do it. You will have to carefully use a vise to hold each unit while you try to work on them. You can use sockets on each of the handle cartridges, but you'll need a special deep socket to work on the diverter stem. Good luck with this one...you'll be cursing grohe after this install.
Similar Threads: removing Grohe
Shower & Bathtub Forum & Blog Help-Removing Grohe Europlus II Tub Handle Jun 6, 2016
Shower & Bathtub Forum & Blog help removing 2 Grohe shower tub handles with no screws! Nov 2, 2014
Shower & Bathtub Forum & Blog Removing Grohe Tub Faucet Handles Dec 23, 2012
Shower & Bathtub Forum & Blog Removing Grohe volume control extension on faucet handles Jun 13, 2011
Shower & Bathtub Forum & Blog Removing Grohe Ceramic Cartridge Apr 4, 2009
