Attached is a picture of our existing tub drain. The sink, tub, and toilet drain is original ~1920s lead into a cast iron stack. A prior owner replaced the tub and connected 1.5" PVC from the new tub drain to the lead drum trap with a fernco (see picture). The bathroom tile floor has a rough hole in it to access the drum trap from above. My wife is not too fond of the hole in the floor, and the tub drain is currently clogged up (the toilet drain seems to be working fine).
We are wondering if we could replace the drum trap with a 1.5" PVC trap, and still tie into the existing lead drain with a fernco or something similar. Is there a reason that all the lead needs to be replaced? It appears to be in good condition, and is not currently leaking. Will removing the drum trap lead to less clogs? We are also wondering whether the slipfit plastic drain should be replaced with glued PVC to enable future snaking, and reduce the chance for leaks. This tub is the only tub / shower in the house, and needs to serve 2 adults (shower) and 2 toddlers (bath).
Thanks in advance for any suggestions!!
