Removing Cast Iron Drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jim.gary, Jan 26, 2009.
  1. jim.gary
    jim.gary New Member
    Jan 26, 2009
    I am removing a 4" cast iron drain and replacing with PVC. Looks pretty simple, small home with crawl space. Problem is finding a 4" PVC T with a 2" tap on side for bathtub,(to match the cast iron I'm removing). Because of limited crawl space, stacking 2 Ts may be a problem. The home has one central stack for all drains.
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
  4. jim.gary
    jim.gary New Member
    Jan 26, 2009
    Thank you, That is it, now hopefully I can find it locally.
    Thanks
    JWG
  5. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Maybe those at the link below can point you to someone who stocks it. But you can try calling real plumbing supply houses, now that you have what it's called. Shouldn't be too uncommon at supply houses for the trade.
    http://www.charlottepipe.com/Default.aspx?Page=SalesUS
Similar Threads: Removing Cast
Plumbing Forum, Professional & DIY Advice Removing Heavy Rust from a Cast Iron Drain Insert Oct 9, 2012
Plumbing Forum, Professional & DIY Advice Removing 4" cast iron waste line Aug 7, 2012
Plumbing Forum, Professional & DIY Advice Removing Lead/Oakum from cast iron - replacing tub/sink drain line - pics Feb 8, 2012
Plumbing Forum, Professional & DIY Advice Removing PVC threaded section from cast iron Apr 30, 2010
Plumbing Forum, Professional & DIY Advice Removing Cast Iron with limited access Jan 5, 2010
