removing brown stains on grout without acidic product (don't want to etch it)
Discussion in 'Shower & Bathtub Forum & Blog' started by AcidWater, Nov 5, 2013.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    Just noticed that the 1966 shower tiles have a lot of brown stains in the grout. Got a product for stain removal but it says it might etch older tile, so I'd like to avoid using it.
    Bigger project is fixing the areas where the grout has come off, in 1/4" to 3/4" long strips. The grout line is really thin; less than 1/8" so the standard scraper I can buy is too wide. But wider than a grinding wheel on a Dremel. Maybe I can find some sort of a burr with the proper diameter to fit the width. Can I then use sealer over both old & new grout?
  2. John Bridge
    John Bridge Mudmeister
    Sep 4, 2004
    Owner, John Bridge Services
    Houston, Texas
    Try cutting a hacksaw blade into 3-inch segments. You can grip them with a visegrip type tool. I have also used a utility knife, but that old grout is probably too hard for that. ;)
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Assuming the brown staining is rust, Super Iron Out does a good job for me and has not damaged the tile.
    As for removing grout, the Fein tool gets good reviews.
    [​IMG]
  5. AcidWater
    AcidWater Member
    Oct 14, 2008
    I'll try the Super Iron Out...
    Actually I have the Dremel version of the Fine tool... haven't used it on anything yet. Wonder if there is a way to attach a fence to control the depth.
Similar Threads: removing brown
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Price Pfister Avante, Help with removing trim plate Nov 14, 2016
Shower & Bathtub Forum & Blog Help-Removing Grohe Europlus II Tub Handle Jun 6, 2016
