Removing basement shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by crjcpm, Aug 28, 2006.
  1. crjcpm
    crjcpm New Member
    Aug 28, 2006
    Yuma CO
    We have to move our existing basement shower stall as it was so poorly installed and framed in. We have to remove the drain to get the stall out-how do we do this? The house was built in 1979. Looks like a brass ring with a rubber gasket. Do we need special tool, lots of $$$.... Thanks.
  2. jimbo
    jimbo Plumber
    If you see a castellated nut, it is securing the rubber gasket. You could use a hammer and screwdriver to remove the nut. Then pry out the gasket, and the shower pan will lift up off the pipe. The drain fitting itself is secured by a large nut under the pan, so it does not come out until you have access underneath.
  4. crjcpm
    crjcpm New Member
    Aug 28, 2006
    Yuma CO
    Jimbo-we are not sure if there is a castellated nut. Do we just pry out that brass ring? This is a fiberglass stall.
  5. crjcpm
    crjcpm New Member
    Aug 28, 2006
    Yuma CO
    We think it is a lead and oakum joint-he scratched the top and there was lead. How do we remove the lead and oakum?
Similar Threads: Removing basement
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Price Pfister Avante, Help with removing trim plate Nov 14, 2016
Shower & Bathtub Forum & Blog Help-Removing Grohe Europlus II Tub Handle Jun 6, 2016
