Removing a shower pfister valve
Discussion in 'Shower & Bathtub Forum & Blog' started by garyji, Aug 3, 2013.
  1. garyji
    garyji New Member
    Aug 3, 2013
    I'm having trouble removing a shower pfister valve.
    How do I get the stem out?
  2. hj
    First get a 1/2" drive socket which fits into that sleeve snugly, usually a 15/16" one. Then use Chanelock pliers to unscrew the sleeve, the socket will keep the sleeve from distorting. Then you can unscrew the stem with a deep socket or a faucet socket wrench.
  4. garyji
    garyji New Member
    Aug 3, 2013
    Thanks! Got it out. Now to find what looks like a very large washer. Is this a unique pfister washer? The OD of the cup that holds the washer is about .75 in.
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    The washer is trade size 3/8L. You also need the seat the washer seals against (that is why the washer is ripped up). The OEM # is 970-500 for the seat.
  6. garyji
    garyji New Member
    Aug 3, 2013
    Thanks so much to everyone for all your help! Problem solved! :)
  7. hj
    quote; Problem solved!
    For now. If I, or some other good plumber, had fixed it, we would have made it a "lifetime" repair so you wouldn't have to worry about it any more.
Similar Threads: Removing shower
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Help removing shower diverted May 24, 2016
Shower & Bathtub Forum & Blog Help removing shower hardware May 11, 2015
Shower & Bathtub Forum & Blog help removing 2 Grohe shower tub handles with no screws! Nov 2, 2014
