Remove Excess Solder after I sweat pipe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by imunwell2, Nov 27, 2007.
  1. imunwell2
    imunwell2 New Member
    Oct 17, 2007
    I sweat some pipes and as most new at this do, I have excess solder blobs at some of my joints. :(
    Will these cause me any problems or are they just a cosmetic issue? If I need to remove them, how can I safely do it without compromising the joint? They have already cooled.
    Thanks in advance!! :D
  2. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Re-heat and wipe with a rag.
    Tom
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It's really just a cosmetic thing. You get better at leaving a joint looking go with practice, but sometimes because of the location, it becomes difficult. I learned to sweat joints when I installed an air supply system in my shop. The joints were/are just butt ugly. However, only on leaked and after 7 years they are all holding just fine. Later joints in my house water supply look somewhat better although still nowhere near professional standards. I know I waste solder and flux, but everything hold which is the point of it all, I think.
  5. JeffH
    JeffH New Member
    May 21, 2006
    California
    Just a word of caution, sometimes OD blobs are indicitive of using to much solder in general. An excess of solder on the ID of the pipe will cause restricted flow.
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    It is best to give the joints a good wipe so you clean any flux off and so you can make sure you got the solder all the way around. If you have a joint that is hard to solder wiping it sometimes solves a problem.
  7. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Of course you do; make it look like you care. Wipe it clean so that if you need to work on this line in the future....you can do so easily without having to cut around the green corrosion and drips of slobber.
  8. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    1/2 in solder for 1/2in fitting and as pipe gets larger adjust to size.
    Wipe them still hot liquid.
  9. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Don't use a synthetic or synthetic blend rag to do the wiping. :D
  10. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Wait till the joint tins up before you wipe it. If you wipe while it's still wet, you smear solder around the pipe and fitting. You can also disturb the joint and cause it to leak.
Similar Threads: Remove Excess
Plumbing Forum, Professional & DIY Advice Remove PRV and Connect Straight Pipe Friday at 11:29 AM
Plumbing Forum, Professional & DIY Advice How to remove early 2000s Moen Shower Handle Mar 2, 2017
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Feb 20, 2017
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
