Morganza
- Messages
- 2
- Reaction score
- 0
- Points
- 0
When changing a 15 yr old bathroom sink faucet, I quickly discovered that both shutoff valves leaked badly when moved from "open" position. When I took them off for replacement, I was then unable to remove the compression ferrule or nut on either one. There is very little room to work on it under the sink, so I just installed the new valves using the original ferrule. My concern here is that in order to get a leak free installation, I had to tighten the compression nut more than I would have thought necessary had I been using all new materials. Everything seems to be working fine now, but I am concerned that there may be a problem (disaster!) in the future because of my having to put so much pressure on the compression fitting in order to get it to not leak.
Question 1: If the fittings are not leaking now, is there potential for failure later on, due to overtightening the compression nut?
Question 2: Should I leave everything as it is and go worry about something else?
My other concern is that if I do go in and cut out or otherwise remove the old ferrules and nuts, will I have problems getting another ferrule to seat properly? If the ferrule was not overtightened originally, I'm pretty sure that it is now!
Thanks for any comments . . .
