Hello,
Im new to the toilet forum and need some advice. I pulled toilet out and found it was leaking underneath not positioned appropriately and was wobbly. Anyhow, remodeling entire bathroom as was my husbands late fathers home from 1970's. I have removed the flange but noticed a lip on the attached pipe not sure what to do next. Do I get a flange (adjustable to go under the lip or do you add a flange to go over the lip. Can I just take the lip piece off and if so how. The pipe is a type of metal. Putting in flooring that is 10mm in height so should make it flush when I'm done as pipe is able to move up and down. It also seems to be a hair tilted to the front not sure if it matters once the wax ring is on..
Thank you for your help.
