Remodel wall hung toilet
Discussion in 'UPC Plumbing Code Questions' started by TCor, Jun 3, 2014.
  1. TCor
    TCor New Member
    Mar 10, 2014
    I'm remodeling a second floor bathroom and changing toilet to wall hung. Venting this bathroom stack seems to be a little tricky due to wall hung toilet and space limitations with framing and trusses between floors. I came up with the following diagram that should work... Does anybody see any issues with the plumbing/venting? Note that I may have to change the wye that comes off the soil stack (for toilet vent) to a tee depending on space limitations.
    Thanks for your help.
  2. hj
    I assume you are using a toilet with an "in the wall" tank, otherwise the vent would come out of top of the carrier, and the toilet "outlet" would be part of the carrier, not an elbow.
  4. Terry
    Aug 17, 2004
    It all likes good.
    The double lav can also be a 2.0" x 1.5" x 1.5" x 1.5" fixture cross.
    The way you have the lav drain is what I do on a 1.5" drain. For code, a double lav needs a 2" on the down hill side, but sometimes on remodel with only the 1.5" waste I will plumb it that way. It does snake better too.
Similar Threads: Remodel wall
UPC Plumbing Code Questions remodeling and want to make a change to my drain lines May 20, 2014
UPC Plumbing Code Questions Laundry Room Remodel Using Existing Vent Aug 5, 2011
UPC Plumbing Code Questions Proposed drain and vent for bathroom remodel, UPC Jul 5, 2010
UPC Plumbing Code Questions Running sink drain in same wall as heating vent Mar 21, 2016
UPC Plumbing Code Questions Single Wall Boiler Vent - Combustibles Clearance Oct 27, 2011
