relocating drain in a slab floor - concerned about floor
Discussion in 'Remodel Forum & Blog' started by yvrtogo, Jun 10, 2010.
  1. yvrtogo
    yvrtogo New Member
    Jun 10, 2010
    Vancouver, BC
    We want to relocate our washer/dryer about 10 ft from its original location. We have a slab floor, so re-routing the drain would mean digging a trench in the slab floor to run the new drain pipe.
    My concern is the cutting up the slab floor part - all the plumbers I've talked to have no issue with it, but I'm concerned for my foundation. Would cutting into the slab affect the foundation? The house is ~ 35-40 yrs old - and so far the foundation & slab are in great condition.
    Any suggestions to allay my fears would be welcome.
  2. hj
    it is the way we do it all the time. we do it with jackhammers and sledge hammers and never damage anything
  4. jadnashua
    Normally not a problem. But, if your house is built using a post-tensioned slab...big problems. Post-tensioned slabs have steel cables embedded in them that are terminated in a threaded connection and they are tightened after the slab is poured. They help in earthquake country and on less than ideal soil conditions to keep things from cracking. Cutting through one of those cables can be very dangerous.
  5. hj
    Post tensioned is not likely in a 40 year old home, as far as I know.
  6. Terry
    Aug 17, 2004
    The least amount of damage would be a wet saw contractor. They use a diamond blade cooled with a stream of water so there is no dust.
    Since the slab is cut and not hammered, it stays more intact. Also pouring new concrete back is easier.
    If you go "old school" and use a jackhammer, turn off the forced air heat.
    When those things kick on it can spread concrete dust all over the house.
  7. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    I agree with using a wet saw. The water is still a bit messy, but will control the dust. I dry cut my slab with a diamond blade, but the dust goes everywhere. It gets so bad, that you have to stop often as the dust is so thick, you can't see what you are doing (covers the goggles too). I made sure that the HVAC was off and tried to close off the area to the rest of the house and open windows to let the dust escape, but dust still went everywhere. Even the 2nd floor (with the slab being cut in the basement) saw significant dust.
    You can save some $$ doing it yourself, but prepared to be cleaning everything in your house for some time. :)
Similar Threads: relocating drain
Remodel Forum & Blog Relocating drain! Look good? Nov 5, 2008
Remodel Forum & Blog Advice for relocating sink fixtures May 31, 2006
Remodel Forum & Blog Drain and Vent Pipes Under Slab/not vertical! Mar 29, 2017
Remodel Forum & Blog 2" Drain Pipe in 2"x4" Stud Mar 29, 2017
Remodel Forum & Blog Capping off old shower drain Sep 21, 2016
