Relocating baseboard heater (forced hot water)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tbeau, Jul 22, 2005.
  1. tbeau
    tbeau New Member
    Jul 22, 2005
    I need to relocate my forced hot water baseboard heater to another area of my living room. The area is fairly close by, just need enough space to put in a sliding glass door. How difficult is this for a do it yourself project and what are some of the steps/items etc. that I need in order to do this successfully?
  2. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Not familiar w/ that but doesn't seem like it's anymore difficult than other plumbing projects. Turn off the hot water, drain, add pipe length, done.
    Anybody know?
  4. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    "doesn't seem like it's anymore difficult than other plumbing projects". Now that is what scares me more than anything else, and you have hundred plus posts :confused: Are you out here as opposed to the electrical sites because of plumbing's simplicity?? :rolleyes:
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    tbabu
    boilers, circ. pumps, and controls are expensive hardware. even if you got lucky you may end up with air in system. not really a diy project
  6. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Found a that might help you decide whether to DIY or get a plumber
    Click here Hydronic
  7. PEW
    PEW DIY Senior Member
    Keep in mind it is currently along an outside wall because it is your cold wall. About to be even colder with a door installed. You may want to consider a way to keep the heat close to the door.
    Paul
  8. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Plumguy, I'm with you ! Anyone giving advice that easy about baseboard heat had better give up the ghost !
    Fella,if you've never had the true "JOY" that is dealing with an old hot water heat system and moving baseboard,,,,,,,,,,,CALL A PLUMBER !!
    Cal
Similar Threads: Relocating baseboard
Plumbing Forum, Professional & DIY Advice Relocating Baseboard Hotwater Heater Oct 13, 2014
Plumbing Forum, Professional & DIY Advice Relocating Propane tank for pool spa - anything I should be aware of? Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
Plumbing Forum, Professional & DIY Advice relocating toilet and shower (tub) drain Oct 13, 2014
Plumbing Forum, Professional & DIY Advice relocating toilet - wye or sanitary tee at horizontal junction Jul 10, 2014
