Relocated TPR valve safety ?
Discussion in 'Water Heater Forum, Tanks' started by gmiller, Apr 22, 2014.
  1. gmiller
    gmiller New Member
    Apr 22, 2014
    Washington
    Hello,
    I was doing some work at my mother-in-laws house (Bothell WA), and noticed the TPR valve for her water heater had been relocated. I would like to know if this set up is safe, and code compliant. Hopefully these pictures will help
    [​IMG]
    [​IMG]
    Rheem Waterheater (circa 1999)
    Electric
    50 gal
    I believe the original TPR valve was mounted on the top of the water heater. This hole has been filled with a steel plug (second pic), and the TPR valve was relocated about a foot away on a branch of the hot water supply line that feeds the rest of the house. It seems to me that moving the TPR valve would delay the valve opening if the tank were ever to overheat (the valve would be colder than the tank). And as far as pressure is concerned, wouldn't the flex pipe fail before the valve opened? Either way this setup offended my sensibilities (I'd welcome being wrong on this one).
    Questions:
    1) Is this a good installation? (is it safe? is it code?)
    2) When I get it replaced should I insist it be changed in any way?
    3) Does this mean I have to get a water heater with a top mounted TPR valve?
    Thanks in advance.
    George
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    That's bad IMHO. However the pressure part will still work.
    You can have TPR top or side, but the temp probe should be sticking into the tank.
Similar Threads: Relocated valve
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Monday at 11:17 AM
Water Heater Forum, Tanks T&P Valve Leak Mystery Jan 25, 2017
Water Heater Forum, Tanks Topside T&P Valve Jan 11, 2017
Water Heater Forum, Tanks Question concerning water heater drain valve. Dec 21, 2016
