Relief Valve Leaking
Discussion in 'Water Heater Forum, Tanks' started by Zipeh, Oct 12, 2009.
  1. Zipeh
    Zipeh New Member
    Oct 12, 2009
    Canada
    I was done in the basement this morning then the relief valve on the oil furnance sort of popped and about 4 litres of water poured out. PSI at 30 and temp between 180 and 190. Just started getting cold out in the last week or so. the release valve is still leaking.. steady drip. PSI still at 30. Checked the expansion cylander ( not a bladder one ) and drained it.. was only air..which escaped and the PSI dropped to 0 for a while but is now back at 30 and release valve is dripping again.
    i been reading online for a while now .. but not comming up with solutions. make is Kerr Comet 145 -- furnace is 7 years old and was last checked in march of this year i beleive.
    i would call a tech but its canadian thanksgiving today so been trying to see if its anything i can effect.
    im curious why the preasure keeps going up to high...
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You may get some answers to your question here, but your question should be in the Boiler section of the forum. This section is for household water heater, not boilers.
  4. Zipeh
    Zipeh New Member
    Oct 12, 2009
    Canada
    wrong terminology then .. its a oil furnace that heats my water which also supplies my house with heat through water heated baseboards.
    and i just found the right drain valve for the expansion tank .. and drained out alot of water .. which was sooty.
    when i closed off the valve from the furnace to the expansion tank the psi shot to 30 in 30s and the valve began to leak again. I took out 6-7 bucket of water before deciding to wait for a bit and see if the preasure goes back to normal.
  5. jadnashua
    While that tank could last for a very long time, it does take periodic maintenance, or you'll have that sort of problem. It probably wouldn't be that hard to replace with a bladder tank. Those fail, too, but probably in the order of 7-10 years, and may not need any maintenance in between.
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Not the tank. Your auto fill valve is bad
  7. Zipeh
    Zipeh New Member
    Oct 12, 2009
    Canada
    i am testing that theory now .. gona run down and check it .. i turned off the intake valve and the preasure seemed steady .... left it for 30 mins and... its at 22 psi.
Similar Threads: Relief Valve
Water Heater Forum, Tanks Pressure Relief Valve Issue??? Problem??? Aug 3, 2016
Water Heater Forum, Tanks Pressure relief valve question Jun 24, 2016
Water Heater Forum, Tanks Possible Pressure Relief Valve Leak Jan 16, 2016
Water Heater Forum, Tanks Routing relief valve line across concrete floor Jan 6, 2016
Water Heater Forum, Tanks Water heater relief valve drainage Mar 10, 2015
