Reliability of T-5 fluorescent tubes using electronic ballests
Discussion in 'Electrical Forum discussion & Blog' started by John in herndon, Oct 19, 2013.
  1. John in herndon
    John in herndon New Member
    May 27, 2007
    Retired
    Herndon,Virginia
    I have a 3 lamp fixture which used T-5 (the thin ones) tubes in a ceiling fixture. It has been very unreliable. I had the first on for 6 months and the lamps started to fail. Sometimes it would light 1 tube, or 2 and sometimes all 3 would light and 1 or 2 would go out after 30 minutes or an hour. I eventually took it back to HomeD and they gave me a new one even though the 90 warranty had expired.
    Well, a few months later and the new fixture is doing it again. I have examined the contacts and connections and removed and replaced the lamps. Sometimes moving the lamps works, sometimes not. I am sure that I don't have a second bad fixture, but who knows. I am sure that they would not replace it again. The manager told me that there is not a high rate of return on these fixtures.
    What gives? I might have a few hundred hours on the thing, and it gets, I am guessing, 8 or 10 turn no/off cycles a day. Do these tubes have a very short life? (they are quite expensive, BTW, $8-10 each). The fixture has 2 ballasts (electronic), one for 1 tube and the other servicing 2 tubes.
    I AM GOING NUTS!
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Some of the cheap fixtures will run the start heater filament at a high voltage and burn it out. If that happens the tube will be black at the ends normally.
    If the pins are clean and a connection is not a problem, Then you can turn the tube around and maybe get a bit more of life out of it.
    I would start by cleaning the pins on the lamps and their holder.
    Good Luck.
Similar Threads: Reliability fluorescent
Electrical Forum discussion & Blog Replacing fluorescent fixture with incandescent Nov 10, 2016
Electrical Forum discussion & Blog Fluorescents in switched zones Jul 14, 2016
Electrical Forum discussion & Blog Outdoor Fluorescent security light question Apr 30, 2014
Electrical Forum discussion & Blog Controlling under-cabinet fluorescent fixtures with a wall switch Jan 8, 2013
Electrical Forum discussion & Blog Effiency of modern tube fluorescents Oct 9, 2012
