casuall002
I have a house that's about 28 years old. For the last few months we've been having issues with water pressure when any other item is on. For example, the hose outside could be on and the pressure drops everywhere else. Flush toilet, run diswasher, run washer, etc...same problems.
I tested the psi outside and right under where the washer hookup is and got about 40-42ish. (there is also a whistle in my pipe.)
The water company came out today and said the Water Pressure Regulator needs to be replaced. So, here's some info but also have some questions. What I have is
Watts
ASSE- 1003
Number- 25AUB
25-75 Range
My questions are:
I appreciate everyones help!
Watts
ASSE- 1003
Number- 25AUB
25-75 Range
My questions are:
- What would you recommend me replacing it with and why? (Brand, Model, etc...)
- How do I know what to set it at?
- My dad, father in law, brother in law are all more than handy from plumbing, hvac, construction, etc...so replacing it should be no issue however, is there a good set of instructions/recommendations around here?
- Is there ANYTHING else you would recommend or suggest?
- Regardless of the unit failing or not, why would the PSI be so low??? He said everything coming through the service line was fine with no leaks or issues
